Displays Layer 2 VPN liberally retained labels received from a peer.
| ipaddress | Specifies an IP address. |
N/A.
If no options are specified, tabular information for all Layer 2 VPN liberally-retained labels is displayed. The following table describes the display fields that appear when this command is entered.
| Field | Definition |
| Advertised Label | Advertised Label is the label advertised to other routers. |
| Destination Mapping | Destination Mapping displays the destination IP address and mask. |
| LSP Flags | LSP Flags lists the flags for each label, which are described in the key at the bottom of the display. |
| Peer Label | The peer label that replaces the received label of incoming packets during a label swap on a transit LSP. The peer label appears only for transit LSPs. |
| NHop Type |
NHop Type helps define the handling of a packet arriving with the specified advertised label. Possible values are: VPLS—The label on the packet is stripped and forwarded according to the service configuration of the VPLS specified in the Name field. |
| Next Hop | Displays an interface ID for the next hop router, which can be a VLAN name, VMAN name, or IP address. |
| Name | Displays a VPLS name. |
| Received Label | Received Label displays the label received from other routers. |
The following command displays liberally-retained Layer 2 VPN labels received from peers:
show mpls ldp label l2vpn retained
This command was first available in ExtremeXOS 12.5.
This command is available only on the platforms that support MPLS as described in in the Switch Engine v33.1.1 Licensing Guide document.
